или если с языком хорошо,то:
00515 - Camshaft Position (Hall) Sensor (G40)
00515 - Camshaft Position (Hall) Sensor (G40): No Signal
Possible Causes
Wiring to Camshaft Position (Hall) Sensor (G40) faulty
Possible Solutions
Check Wiring to Camshaft Position (Hall) Sensor (G40)
Check/Replace Camshaft Position (Hall) Sensor (G40)
Check/Replace Engine Control Module
Special Notes
Some older engines store this code as long as the engine is not running, if in doubt read fault codes with the engine running again.
00515 - Camshaft Position (Hall) Sensor (G40): Implausible Signal
Possible Causes
Camshaft Timing Out of Specification
Engine Control Module faulty
Possible Solutions
Check Camshaft Timing
00515 - Camshaft Position (Hall) Sensor (G40): Open or Short to Plus
Possible Causes
Camshaft Position (Hall) Sensor (G40) Installation faulty
Possible Solutions
00515 - Camshaft Position (Hall) Sensor (G40): Short to Ground
Possible Symptoms
Power Loss
Emissions not OK
High Fuel Consumption
Possible Causes
Possible Solutions
