Ошибки vag-com
Сообщений в теме: 2
#1 Иван18
Иван18
  • 23 Cообщений
  • Автомобиль: Audi A4 B8
  • модель: пока нет
Отправлено 25 Май 2015 - 17:19
Доброго времени суток! Подключил сегодня кабель к машине  и получил следующее:
Address 01: Engine (MSTR-CDNB)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 Q    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0003
   Revision: E1H14---
   Coding: 0104000C18070160
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TFS8K2907115Q A01005
   ROD: EV_ECM20TFS8K2907115Q.rod
   VCID: 3D7B272DAC6A8F1
9 Faults Found:
4629 - ECM Power Relay Load Circuit: (J271)
          P068A 00 [040] - De-Energized Performance Too Early
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 5
2811 - ROD - Unknown Error Code
          - FB [096]
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 97032 km
                    Date: 2015.05.12
                    Time: 12:13:46
4007 - Idle Control System RPM
          P0507 00 [104] - Higher than Expected.
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 97075 km
                    Date: 2015.05.12
                    Time: 14:24:10
4060 - Cylinder 3
          P0303 00 [096] - Misfire Detected
7960 - Cylinder Disabling
          P130A 00 [032] - -
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
7781 - Engine Off Timer Performance
          P150A 00 [032] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 96942 km
                    Date: 2008.05.27
                    Time: 00:15:41
4219 - EVAP Emission Control Sys
          P0441 00 [096] - Incorrect Flow
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 96942 km
                    Date: 2008.05.27
                    Time: 00:10:54
4261 - System Voltage
          P0562 00 [096] - Too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 96942 km
                    Date: 2015.05.08
                    Time: 18:52:21
Readiness: 0000 0000
 Address 08: Auto HVAC       Labels: Redir Fail!
Control Module Part Number: 8T1 820 043 T    HW: 8T1 820 043 T
  Component and/or Version: KLIMA 1 ZONE  H06 0140
           Software Coding: 64000000
            Work Shop Code: WSC 02399 823 56573
                      VCID: 428154D1DD94F09
1 Fault Found:
01271 - Positioning Motor for Temperature Flap (V68)
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 11
                    Mileage: 97604 km
                    Time Indication: 0
                    Date: 2015.05.24
                    Time: 20:00:41
             Freeze Frame:
                    Voltage: 11.60 V
                    Temperature: 19.0°C
                    Temperature: 15.0°C
                    Count: 11218
                    Count: 11778
                    Bin. Bits: 00000000
                    Bin. Bits: 00000111
подскажите!!!!!
#2 DiCh
Отправлено 26 Май 2015 - 15:15
Что именно подсказать?
#3 Иван18
Иван18
  • 23 Cообщений
  • модель: пока нет
Отправлено 27 Май 2015 - 10:12
по ошибкам. Что и как. ЧастИчно я расшифровал И более иЛИ менее понял что делатЬ
